Kyle308
Hey guys I just put a 15 charger in 13 truck Friday first time I've done the swap I was under the impression that we can do the swap without ******** anything else. So the truck is 100% stock except the 15 turbo. I was having issues with a wastegate check engine light. So I had ********** write some tunes for it and now I don't have a check engine light but I do have a low boost and serious lag issues. It only sees 16psi max. I'm going to put the scanner on it tomorrow and see if there is anything obviously wrong. But I wanted to see if anyone has had a similar issue or has successfully swapped a 15 turbo in a stock truck. Cause what I keep hearing is it won't work with the *** on it. Thanks in advance
