B.Warning
1987 9370 Binder, 650k miles, 220" wb, 3406B Cat (supposedly 500hp) 9spd, spring ride, I believe 4:10 gear, protech headache rack, 24.5 aluminum, fronts @ 50%, rear could use replaced. Previous owner claimed it had a in frame overhaul but no paperwork to verify. Although the engine is spotless with zero leaks. 5th wheel is tight, new batteries and starter. I had it painted, was previously white and polished up tanks and wheels. Good, solid, heavy built truck.
$13,000
Located in LaGrange Mo
$13,000
