1995 F-Superduty 4x4
FL
I was recently fortunate enough to come across a 1995 ford F-superduty 4x4.
I am looking to see if anyone knows who sells 19.5” Alcoa style wheel for these old trucks.
also, any info on the running gear would be interesting. From my research it’s a D70 front and D80 rear.
ncollins64
winchester springs, tn
No F Superduties only came in 2wd. But yes the rear is an 80 and the front I’d suspect to be a 60 but you can always pull the numbers on it and look it up to verify.
Strokersace
Towanda, KS
I’ve been around several 4x4 f-superduty obs trucks. Each one was a 460 5spd. The last one was a green BLM/forest service truck. If it wasn’t factory, I’d be shocked.
FL
They did not come factory from ford 4x4, but were sent off to places like quigley 4x4 to be modified.
This truck is a 7.3 with a zf5. It’s a retired Florida fwc truck. The 4x4 10 lug is extremely rare.
F
Floorboard79
Guest
Beautiful truck there.
Did the C&C 350 drw's come in 4x4? Mine appears to be that way from the factory?
Lt.Dan
Visalia, CA
Yes. I want one pretty bad too.
There's a guy i saw on Instagram (back when I got on there 4 or 5 years ago) that had a 95 Quigley CCLB 4x4 FSuperduty with like 30k original miles on it. Beautiful red paint and interior, and he was pulling it out of his storage to do some resto and a lift/wheels and tires etc. Supper clean and I want!
JTS
No one makes the wheels you're looking for.
But, the 10x7.25 bolt pattern was also used on 90s chevy 3500HD trucks and P30 chassis. A lot of winnebagos were built on P30 chassis. A lot of winnebagos had 19.5 alcoas.
You see where this is going?
I bought a complete 1985 winnebago for $500 with a blown motor, bought a set of steel 19.5s off a 3500HD for $200 then swapped them onto the winnebago and resold the winnebago for a small profit. Then dropped all 4 aluminum and 2 steel 19.5s at a machine shop to have the hub bores bored out to fit the f-superduty.
It was a pain, but i got basically a free set of hard to find wheels.
Sent from my SM-J737P using Tapatalk
