2.5" Readylift spacers w/ 4" rear blocks
NCSU dirt man
Ft. Bragg, NC
As stated I have for sale 2.5" front Readylift spacers with 4" rear blocks and u-bolts (same height approximately as F350 blocks). Looking for $150 plus shipping. DM me for more info or PayPal. Thanks
NCSU dirt man
Ft. Bragg, NC
Was this on your 2011? Dibs if they'll work on my 2008. Can I get the part numbers off the boxes?
replied jus10keith.
they will work on an 08
thanks Sootie for the clarification I thought they all would work on an 08+ truck as a friend of mine with an 09 F350 SRW has this same kit. I believe the blocks won't work on the 05+ trucks however, correct?
the blocks should work on any truck with single alignment pin.
longer shocks will be required unless you dont mind topping out over bumps. You will need the correct u-bolts for an 08 , yes. They point upwards and have a different radius than 11+
