2003 f350 7.3l
Gametrap
Tennessee
Lost 4rth gear ( overdrive) rebuilt transmission with new clutchs, sonex ring, and tugger hd 2 shift kit and new shift solenoid pack
Still no overdrive
Checked od button and wires
Powerstroke Cowboy
Montana
What are the symptoms? Does it try to shift into OD? If it does not even try to shift, there's a good chance you have a bad shift solenoid.
Gametrap
Tennessee
Has a new shift solenoid in it, just want go into 4rth all other gears shift great tc locks like it's supposed to just no 4rth gear
Powerstroke Cowboy
Montana
Was the transmission working properly after the rebuild? The shift solenoids control the shift. If it's not the solenoids then it's wiring.
ncollins64
winchester springs, tn
Ok just to clear it all up, you lost overdrive, had the trans rebuilt and ever since the rebuild it shifts and runs perfect up to overdrive and then doesn’t shift into od?
