2004 Excursion 6.0 2WD FS - Maryland
birdmayon
Southern MD
2004 Ford Excursion, Eddie Bauer with 6.0L. This excursion is 2WD. 173,000 miles. $15,500. Toreador Red with bronze/gold two tone paint, and two tone tan leather interior. Bench second row seating.
Fully bulletproofed at Marty’s Diesel including:
New Ford HG's, ARP head studs, new HPOP (including all high pressure oil seals, j-tube, etc), new IPR, Turbo cleaned, updated turbo feed/drain lines, 6.4 banjo bolts, EGR delete, Marty’s regulated fuel return, Bulletproof Diesel billet water pump, Bulletproof Diesel relocated oil cooler (utilizes stock oil filter and housing, and includes a 185 degree thermostat for cold weather……….never replace another oil cooler or worry about watching your deltas!), Bulletproof Diesel FICM, 4 new injectors.
Also completed within the last 14,000 miles: new coolant cap, transmission and differential fluid change, new pinion seal, coolant flushed and changed over to ELC, new glow plugs and glow plug harnesses, new batteries, replaced front and rear shocks as well as sway bar bushings and endlinks, new 4” turbo-back Banks Monster exhaust (retained cat, it is as quiet as stock), installed Airlift rear air bags, Pioneer touch-screen CD/DVD player with back-up camera, replaced stock rear DVD player with new, added weathertech mats and cargo liner. Also included: Edge Insight digital display and EGT probe as well as turbo timer, SCT tuner with Gearhead tunes, I have only run the 8k tow tune on it but comes with SRL if you want to play with some real power, or you can return it to the factory tune. Comes with Prodigy brake controller installed.
Tires have good tread. Starts quickly and strong every time. Fantastic family hauler or tow rig. This is a clean truck originally from Texas with ZERO rust/corrosion including the undercarriage. I need to get some decent pics of it once the rain stops here, will update with pics after this weekend.
birdmayon
Southern MD
$15k obo
birdmayon
Southern MD
Inside bottom door edge. Sorry for multiple posts, can't upload more than one at a time from my phone for some reason.
