2008 250 6.4- no tow/haul power
DEKINJR250
Hey guys....tow haul worked until this past summer. I finally dug into it and found no power at the tow haul wiring at the steering column going to switch. the fuse shows good on passenger side. Anything else control the power to the switch I may be missing?
Mesa, AZ
Check for chafing on the harness where it runs across the top of the steering column. Really common, typically its on the shifter side though.
