jtpappy
Previous owner purchased this truck stock at 37k miles and didn't modify it until 60k most of this work was done just this past year.
The truck has had 3 owners, myself included, always been a Maryland truck.
Its ran a 12.46 @107 w/ 1.63 60' weighing at 7700 lbs, just nozzles and stock trans. Has never been to the track since the new motor or with the tow powers.
Here is a list of what is done to the truck -
New oem heads, O ringed (5k miles)
New OEM Ford complete bottom end
ARP head studs
RCD push rods (5k miles)
New oem lifters (5k miles)
60% injector nozzles (5k miles)
MPD waste gate egr delete kit
Airdog II lift pump (5k miles)
Sinister coolant filter kit (5k miles)
RCD tow power turbo set up 72/59 batmo wheel (5k miles)
New oem front cover (5k miles)
New oem water pump (5k miles)
New primary tensioner (5k miles)
New oem radiator (2012) w/ warranty
850 cca batteries (2011) w/ warranty
MPD built transmission $4500.00 (8k miles)
Precision torque converter (1000 miles) w/ warranty
BTS forged & cryogenically treated input shaft (1000 miles)
SDP 5" cat & dpf delete pipe
SDP 4" ceramic coated downpipe
Magnaflow S.S. 5" dpf back exhaust w/ 6" tip
No limit intake
Mini maxx with custom tunes
Pioneer DVD navigation head unit. ($1600.00)
Linex bedliner
35"X12.50"X20" Nitto Trailgrappler M/T tires 40% tread
Rancho RS9000 adjustable shocks
Front end leveling kit
Caltracs rear traction bars
New oem front brake pads (2k miles)
New oem rear brake pads, new rotors and backing plates. $500.00 (2k miles)
Job 3 Ford degas bottle, thermostats, and upper radiator hose.
NO LIMIT CAC tube
Diesel Site heavy duty charge pipe couplers and clamps
New window tint last year 5% on the rear, 25% front windows
I have all the receipts for all the work including at MPD, and the radiator at ford, including the block, that was warranty work
Call or text 301-542-7668
The price is 36,000 or obo
No trades
ARP head studs
No limit intake
Linex bedliner
NO LIMIT CAC tube
No trades
