2008 F250 eclb
gorace
2008 f250 eclb xlt late build
Truck is a 6 speed, fully built motor 20k on motor driven across the country with no problems.
202k on the chassis.
Truck was fully repainted 2 years ago no dents scratches etc. Clearcoated with house of color clear 3 coats. New tailights has rhino liner.
New grill
Interior is a 9. It has no rips tears I put new foam and lower factory seat cover. Everything works. Has fx4 navigation and surround as well as the window control covers. Weather tech floor mats. New black leather steering wheel.
Motor has
Fully preped block bored honed 20 over
delipped coated pistons
total seal second ring
clevitte bearings
colt stage 2 cam
All new oem gaskets
Arp head studs harmonic flywheel hub
Reman ucf heads new hardened valve seats, better valve guides, rivercity valve springs and keepers, also have the fire ring so no blown gaskets
Rcd intake manifold
Rcd 59 72 turbos
New oil pump oem
New front cover and pump thermostats
New ford fuel pump and injectors
New fuel lines and rails
New water hoses upper lower heater core hoses
New radiator
Banks intercooler
Afe 4 inch exhaust
Afe stage2 intake
Rcd elbow egr ******
Fully ******d but will come with all the oem parts
New air dog 2 Filters and oul changed every 10k oil every 5k with ford oil and filters.
Runs on a custom ******** tune on tow mode.
Transmission was completely gone thru new synchronizers I can go into more detail if you ask
South bend clutch twin disk and clutch bracket new hydraulics
Tru track rear diff and eaton elec locker in the front. Both diffs have new bearings and seals
Truck has f 350 rear springs with over loads.
bw gooseneck
Im sure im missing a lot of stuff but just ask if you have questions.
Have pics of the whole build over 50 pics
Asking 26k but will listen to offers.
Clean title
You can call me at 9167996468.
Or email at [email protected]
My names Christian
Willing to work with buyer on shipping
gorace
Thanks, all offers will be considered.
Has bilstein shocks too.
Changed front body mounts already too.
Always been a california truck so no rust.
gorace
Would trade for a skid steer ormini excavator of equal value could put money on top if needed
Evidently nobody wants a rowboat anymore.. looks well built and a gorgeous truck that is priced right. I cant believe its still for sale! Good luck man!
