2010 OEM Power Everything tow mirrors
300000 and counting
Ohio
I have a set of tow mirrors off of a 2010 f350 for sale, they are power fold/ power extend/ have memory/ heat/ turn siginal/ marker light/ power upper mirror. These work perfectly and look great (no marks/ scuffs on them), the mirror cap on these are permanent and that is why I am selling them. The only thing wrong with them is the lower spot mirror on the passenger side is broke, its easily replaceable and cost $82 from ford (a lot less if you can find an aftermarket one) I'm asking $550 shipped to your door.
Note: In the video the up and down function won't work, that is because these have memory and my truck does not, if you don't have memory I'm told you can wire them to work anyhow but I can't confirm that.
fubolislif22
will you sell me the drivers side mirror? My power fold does not work and its really irritating me... Also can the caps be painted? My truck is white.
PM ME
Thanks,
01F250SD
PM Sent
PM Sent. I'm also curious about the wiring issue based on the memory function. I installed a set and might be able to figure it out. Are the OEM connectors on both sides (mirror and truck) included?
rosspulliam
DFW
See my post here for links to buy the OEM door side connector and pins.
bigrpowr
<How I Fly
Administrator
geez why didn't i see your post a long time ago ! i have the power folding mirrors, and the switch, and i swapped the harness to a vin with power folding, but it still doesnt work. i really dont even care about the telescoping, just the fold. any idea how to wire that switch proper ?
rosspulliam
DFW
Refer back to my update on the thread I linked. I added an update, including a PDF file of all of my notes.
