2015 Turbo
15Platinum67
Selling my 2015 turbo with up pipes turbo had 21,000 miles when it was taken off for non VGT swap asking $1500 IMG_3103.jpg
Brian22
Forney, Tx
There is a guy over on PSN that might be interested in this. The turbo on his 2011 just took a crap in him.
15Platinum67
I will be supplying the stock up pipes for the 2015 turbo I believe the only thing needed is a 2015 down pipe for the exhaust
JRLott
TX
10-4! Now I see where it says with up pipes...sorry about that...
Is there anything else necessary to drop this in to a 2011?
PM sent
to make a 2015+ turbo work on an 11-14 you require:
2015 turbo, pedestal & heat shield, passenger side manifold & heat shield, aluminum lower intake manifold, RH & LH up-pipes, downpipe, all associated gaskets. Some replace the coolant feed line & v-bands as well but not totally necessary.
