BlueFordExcursion
- Joined
- Mar 23, 2014
- Messages
- 21
- Reaction score
- 0
$5,500 - Located in Bellingham MA - Up for sale is my entire motor. Super clean, daily driver, smooth power, over-maintained. All work and maintenance done by the same diesel performance shop in eastern Mass. Inovative tuning 100% of the time. Daily tune: 600 hp. Full fuel tune: 700hp! Dyno sheet to prove power numbers. Everything is built right, no corners cut ever. I am swapping over to a 1000+hp 5.9 Cummins. I am keeping the 6.0 wiring harness and FICM.
118K on long block, 40K on heads, 15K on performance parts
Motor:
EGR ******d/Oil Cooler replaced
ARP Head Studs
PowerMax Turbo
DieselSite Wicked Wheel 2 for powermax
Swamps 170/50 Injectors
Driven Diesel Regulated Return
DieselSite High Volume HPOP
No Limit Fab hot and cold pipes
AFE high flow air cleaner
AirDog 100
NUC Motorsport remote oil filter
SCT 3015
********** FICM tuner
New ICP and IPR sensors installed with HPOP install
New standpipes, turbo drain tube, and high pressure oil lines installed with injector install
You can't even buy the performance parts for this amount!
Motor:
ARP Head Studs
PowerMax Turbo
AirDog 100
SCT 3015
