6.0 Important Ford Part Numbers
faster6.0
Mods a sticky for this one would be good.............
6.0 Power Stroke Part Number Part Price
High pressure Oil 6E7Z-9A332-B Up Dated Stand pipes $102.00
4C3Z-9F838-A Late Build ICP sensor $99.00
3C3Z-9F838-EA Early Build ICP sensor $99.00
5C3Z-12224-A ICP Pig tail connector $49.21
3C3Z-9C968-AA Early Build IPR $179.10
5C3Z-9C968-CA Late Build IPR $159.91
3C3Z-9A543-AARM Early Build 6.0 HPOP
4C3Z-9A543-AARM Early Build 6.0 HPOP
5C4Z-9A543-A Late Build 6.0 HPOP
5C4Z-9A543-B Late Build 6.0 HPOP
4C3Z-9B246-F STC Fitting
W302908 Up Dated Dummy Plugs
Injectors 3C3Z-9E527-ECRM Early Build Injector $400.00
4C3Z-9E527-BRM Later Build Injectors $400.00
FICM 4C3Z-12B599-ABRM Fuel Injector Control Module
Fuel Pressure Regulator 3C3Z-9T517-AG Fuel Pressure Kit $51.70
Gaskets 3C3Z-9433-BE Intake Gasket Set $87.00
W302725 PCV O ring $3.88
3C3Z-9T514-AD Turbo mounting Kit $12.97
5C3Z-6079-B Head Gaskets $135.30
3C3Z-6051-CA Early Build Head Gaskets
4C2Z-12A690-BA Glow Plug Harness L
4C2Z-12A690-AB Glow Plug Harness R
6C3Z-9448-A Exhaust Manifold Gasket
Coolant System 4C3Z-9P456-AF Late Build EGR Cooler
6C3Z-8A080-B Degas Bottle
9C3Z-8101-B Degas Bottle Cap
3C3Z-6A642-CA Oil Cooler
Base Engine Oil System 3C3Z-6A642-CA Oil Cooler Kit $213.99
3C3Z-6C683-AB Screen under oil cooler $6.78
3C3Z-9T516-A Updated Turbo Supply $76.96
6C3Z-9T515-A Updated Turbo Drain $20.90
3C3Z-6675-AA Oil Pan
3C3Z-6710-BA Oil Pan Gasket
3C3Z-6626-AA Pick Up Tube O Ring
W300002 Oil Pan Bolts Short
W300014 Oil Pan Bolts Long
PM-13-A High Temp Coating
Turbo Charger 5C3Z-6F089-BA VGT solenoid
3C3Z-6K682-CCRM Turbo Assembly
3C3Z-6P854-DA Turbo Up Pipe
5C3Z-9G489-AARM 04+ CHRA
6C3Z-6C640-AA Metal Cold Side CAC Tube
Filters FD-4616 Fuel Filters $49.49
4C3Z-9601-AA Air Filter $50.73
FL-2016 Oil Filter $19.14
6.4 banjo Bolt kit W302472 *2 Bolts $9.92
W303659 *4 Washers
harrisford
How about a unision ring number and blue spring upgrade number? I dont have either but they would be handy
91turbogsx
Gardner MA
Upgraded fuel pressure regulator kit (with cover): #3C3Z-9T517-AG
Fuel Pressure Regulator "Spring and Reseal Kit Only": #6E7Z-9C165-B
Regulator cover gasket only: #3C3Z-9C065-AA
Unison ring: 3C3Z-6C885-A
