6.4 Engine parts and transmission
bigfords
Located in Trout Run, PA.
I don't have any tailgate tops that are not on good gates I'll check on the power seat control plastic but I believe it is tan.
Hopefully get back to you on that starter tomorrow!
bigfords
A 6.4 short block? I have one that is already disassembled. It spun a bearing. I'm not 100% sure of the condition of the block, I can take a closer look tomorrow.
Spectre32
I bought a steering gear from bigfords. I put it in no problems and he was super quick and easy to deal with. Cut me a pretty good deal given everything i go, and even ofeered me some piece of mind just in case it did not work. Would buy from again and anyone considering should have no qualms.
bigfords
Thanks Spectre32! Glad it worked well for you!
Sent from my SM-G920V using Tapatalk
djr4x4
Southeast Texas
The lariat that had the sunroof.. Do u happen still have the overhead dome light assembly?
Shipmate
WA.
How much for all EGR stuff. Covering mine back to stock. So I need coolers elbow and all.
