6.4 high pressure turbo batmowheel
6.0dirtworker
Cloud 9
mortal798
Michigan
Bump and a semi-related question: How do batmowheels compare to something like Elite's 71mm atmo? I know you can buy batmowheels for both turbos, is Elite's housing bigger too?
6.0dirtworker
Cloud 9
Elite's 71mm has a bigger compressor inlet that will outflow stock. I'm not sure if they modify any other internals, the turbine side doesn't change. A drop in bmw will net quicker spool up, drop in egts, and a different turbo pitch over a cast wheel.
Bump for steers and queers
:blah: Shouldn't you be working on something?
