60% Injectors on Stock Fuel System?
d.evil
Sparks, NV
Just curious if its worth it now to put the midwest 60% over nozzles in while the truck is apart getting head studs / 72/59mm set-up. I plan on running the stock fuel for now, but have these nozzles kicking around. I was going to put them in when I added fuel to the set up later on, but am wondering if I should do the nozzles now and add the rest later. Or do all of the fuel stuff at once. Thanks
bad idea. No way the stock pump can keep up and just causing more wear on an already dicey part.
Black AOD
Ohio
single k16 cant even maintain full RP on 15% injectors with supporting mods.
Don't bother like Sootie said.
d.evil
Sparks, NV
Perfect, exactly what I needed to know, thanks!
We'll see how long it takes to get board with the 600+HP set-up currently going on before doing the pumps & injectors :popcorn:
Tree Trimmer
or you talk to your tuner and see what he says.
there is no reason he cannot pull fuel out to get back to stockish.
just because you have 60% over, doesn't mean you need to use it.
