7.3 dies when hot need help
e.nickkk
2002 dies when hot I replaced the hpop n hoses still dies when hot with no codes replaced icp sensor I'm running out of ideas and did cam sensor or crank idk by the water pump any other ideas?
e.nickkk
how did u find out what one it was cant hear a leak with shop air?
littleredstroker
where the antelope play
with VC off when its hot, cranking @no start, if its a internal o ring leaking you can see it leaking out at the top of the injector below the solenoid. I was told, and don't know enough about them to know if a external oring will cause a noticeable leak/ not push oil out of the deflector.. maybe someone will chime in who knows more than i
e.nickkk
Icp at idle running is 500 if I unplug icp sensor its 740 @ start up I c icp climb to 2k really fast just before it starts I will try to get it hot n check pressures thanks for the info keep the ideas coming
Rideracelivemx7
Montana
when you replaced the HPOP did you reoring or use a new IPR? like travis said above it could also be an injector oring and youll see it leak pretty good under the valve cover if you take them off.
did you hook up a mechanical gauge?
