7.3 pulling truck, OBS, ZF5
turboTwang6
Holland Patent, NY
Hi all - looking to sell this truck. See parts and pics below. Truck is not put together, I guess you could call it a "kit" - pretty much includes everything to make a good 2.6 puller.
-Swamps 450/400s
-homebrew gen3 pump
-smith bros push rods
-comp 910 springs
-h11 studs
-arp main studs
-air to water intercooler and all necessary piping
-s475 with a t6 1.32 housing and a t4 1.25 housing
-air shutoff
-3" aluminum plenums
-full fuel system with fuellab pump and regulated return
-south bend sintered iron dd 3850
-spools front and rear
-custom ice and weight box
-ts chip with swamps tunes
-american racing rims with half used bf Goodrich a/ts
-im sure I'm forgetting something...
Asking $10,500 OBO. Bought it from my buddy who had it all together at one point. I had the intent to put it together and run it but it's just becoming an eye sore in the yard. You can call/text me at 315-525-3591 if interested. Thanks for looking.
turboTwang6
Holland Patent, NY
Sorry about the pics being sideways. Uploading from the phone, not sure why they are like that. Here are more pics. Btw I'm located in central new York.
turboTwang6
Holland Patent, NY
I also have a good 7.3 long block, a set of good stock injectors, shims for the valve springs. Rear hitch has been moved up and in. Movable stops above the rear axle. Driveshaft loops at every u joint. Upgraded hydraulics for the clutch.
Is that a dana 60 in the front? Im in Syracuse.. im not interested but was just wondering because i cant see if it is a 250 or 350. Price seems ok. But its a lot to get put together.
turboTwang6
Holland Patent, NY
Yep, truck is a 250 with a 350 axle swapped in. Yea it's a lot of pieces, i thought i wanted to be pulling someday but priorities change as we get older haha
10-4 that should help it sell a lil better.
Lincolnlocker, are you living in syracuse? Or there for work? Your info says michigan
Im from central Michigan and im still technically from there but i have been in Syracuse for about 4 yrs now for work. I do have a apartment and im living with my girlfriend that i met out here..
turboTwang6
Holland Patent, NY
10-4 that should help it sell a lil better. Im from central Michigan and im still technically from there but i have been in Syracuse for about 4 yrs now for work. I do have a apartment and im living with my girlfriend that i met out here..
That's awesome. What do ya do for work? I'm over in rome at the air force base
turboTwang6
Holland Patent, NY
Updated list. Easter weekend deal. $5000 takes the truck and all the parts left. I just want this gone and going to a good home.
-homebrew gen3 pump
-comp 910 springs
-h11 studs
-arp main studs
-air shutoff
-full fuel system with fuellab pump, minus regulated return.
-4.56 spools front and rear
