7.3 sellout sale
Status
Not open for further replies.
bruce
Middle east
brand new 300/200 hybrids from PIS 2000+ cores
irate t4 w/s468 1.15ar exhaust housing, less than 10k 2400
full force 250/200 hybrids, built 8/12, less than 5k 1500+ cores
modded h2e, carson's mount, upgraded oil return line, 3.5 dp 1700
irate competition fuel system, dual 392's, pre and post pump filters 5/8's lines, beans sump 1100
headers, had a few cracks professionally welded. will come with gaskets and new oem bolts 800
brand new arp studs, swamps stage 1 valve springs and pushrods 1000
billet stealth, stage 1 1200+ core
brand new mellings lpop 100
brand new isspro ev2 0-1600 egt, 0-60 boost, 0-100 fuel psi, trans temp, with warning programmer 600
brand new 08 finned aluminum rear diff cover 75
injector cup tool, remove and install 200.
7.3 long block, needs rebuilt 400
7.3 long block, was said to run when removed, will check compression but heard lowest cylinder was 395 1200
Anything brand new can be shipped IMMEDIATELY, other stuff you'll have to wait until next monday. If you see somethin you like shoot an offer. Located in Dyersburg, Tn
Strokersace
Towanda, KS
I don't have cores but am interested in a set of injectors. What would you want for them w/o cores?
V-Ref
9 miles high @ 550 mph
Bruce
Tell us all about your modded H2E.
Who modded it? What comp wheel? What turbine housing? How many miles? Does the kit come with an intake already?
bruce
Middle east
I bought it from a guy in central pa, so I would assume barder modded it. 66mm but not sure. Nice setup. No doughnut gaskets like the hypermax kit
bruce
Middle east
has low compression, supposedly ran when pulled though. thats why it bein sold as a rebuilder
Status
