Adding adaptive cruise 2020+
EV0lv3d
First post here so let me start by saying hello!
Obvious disclaimer, I'm providing this info for scientific purposes only, any actions you take with your truck are your responsibility and yours alone.
I made my own mounting system for the CCM and got it used so this may not be a 100% accurate list, this is based solely on parts diagrams I could find. I will update if I find additional information. Hopefully someone can jump in here with better info. This post is mostly to show that it is definitively possible and to list the necessary FORScan changes. Assumes you already have lane keep assist and pre-collision assist.
CCM lb5z-9e731-ab
CCM bracket lc3z-14c022-a
bracket mount bolt 9l3z-19s426-a x4?
bracket mount nut plate w52082-s439 x4?
ccm mount studs w717467-s439 x2
ccm alignment stud w717468-s439
stud nuts w520201-5440 x3
plastic stud mount grommets w717468-s439
steering wheel switch fl3z-9c888-ba
air deflector hc3z-8327-r (6.7 only, others use hc3z-8327-t)
center bumper molding lc3z-8419-ba
tow-hook cover lc3z-8310-e
I couldn't find the proper bumper harness, thus adding to the existing harness, this way cost me about $12 so it may be the way to go anyway.
CCM connector WPT-1198 buy a kit with pins
bumper harness pins 33012-2002 (or just buy mx150 or WPT-1599 connector kit with pins)
will need to purchase pin crimper if you don't have one.
CCM connector -- bumper harness connector
use 20awg automotive wire
Pin 1 -- Pin 4
Pin 2 -- Pin 5
Pin 3 -- Pin 6
Pin 4 -- Pin 15
---------Forscan Changes-----------
I am not a ForScan guru, these are only from personal observation and comparing different models ab data with and without ACC. Please let me know if anyone notices something glaringly incorrect. This works on my truck perfectly with no errors or dtcs (2021 F250 XLT Premium Tremor, 6.7 Powerstroke).
copy vin data from abs module to ccm, offset by the first two numbers
CCM
ABS module reference values (DO NOT CHANGE)
760-01-01 ++++ ++++ ++XX
760-01-02 ++++ ++++ ++XX
760-01-03 ++++ ++++ ++XX
760-01-04 ++++ XX
skip the first two numbers in ccm and copy vin data from abs (first two numbers should be 32)
764-01-01 32++ ++++ ++XX
764-01-02 ++++ ++++ ++XX
764-01-03 ++++ ++++ ++XX
764-01-04 ++++ ++00 00XX
****EXAMPLE DO NOT ENTER****
760-01-01 1234 5678 90XX
760-01-02 0987 6543 21XX
760-01-03 1234 5678 90XX
760-01-04 0987 XX
764-01-01 3212 3456 78XX
764-01-02 9009 8765 43XX
764-01-03 2112 3456 78XX
764-01-04 9009 8700 00XX
ABS
760-03-01 Dxxx xx
SCCM
724-01-01 xxxD xxxx xx (omit if using non acc cruise switch)
IPMA (These changes require FORScan 2.3.42 test20210720 or newer, I obtained a test build through support)
706-01-01 xxxx 9xxx 69xx
706-02-01 xxxx xxxx (7)Fxx (you can use this number to set the following distance if you don't have the acc cruise switch, odd numbers 3-9, nearest to farthest. 7 is default)
BCM
726-16-01 xxxx xxxC xxxx
IPC
720-01-01 x7xx xxxx xxxx
EV0lv3d
I can't edit my post, but HC3Z-8327-R is NOT the correct pn for the air deflector. It is LC3Z-17B968, just trying to figure out the correct revision.
