Adding supplemental heat
Stroked777
Casper, Wyoming
I'm gunna follow this. My window sticker says I have it but I could never tell. Didn't seem to blow warmer to me. Unless a fuse is blown
drunk on diesel
look on your passenger side battery. there'll be a large red cable with a 150 amp fusible link inline.
it doesn't make instant heat or anything, but it definitely helps get things warmer quicker
it's just a small space heater in the HVAC box. it would be a HUGE job to add it I would guess
Stroked777
Casper, Wyoming
Ok I know I got that 150 fuse. Thanks for that. Sorry for the derail. To me it seems like it doesn't warm it up to much. I guess I would have to do a side by side test with a similar truck to mine in the witer that doesn't have it
f350guy
Texas
It seems to work best to me if using the blower fan on lower speeds (similar to A/C producing cooler air on the lowest fan setting). Lowest temperatures I see are maybe mid 20°F area with the occasional dip into the low teens, so not super low but hey it still helps. So does a grill cover.
The air coming out is not hot, maybe tepid would be a good description?
Stroked777
Casper, Wyoming
I usually stuff a piece of cardboard between the rad and IC. Sorry for the derailing lol as far as the topic I'm not sure how involved it is taking the heater box out. Never done it before but I know on a mini can we had in the shop one day it involved taking out the entire dash all the way up to the firewall.
drunk on diesel
agree, my reg cab has it, and I just put floor/defrost on lowest fan setting and while it isn't warm, it's obviously warmer/quicker than my other trucks in the winter
6.4 Stroker
Rapid City South Dakota
It's all good!
I figured it would be quite the task. I didn't know it would require such high amperage. Maybe I'll just let it warm up longer. Lol
I just drive a pretty short distance to work and don't have access to a cord for my block heater.
Stroked777
Casper, Wyoming
Did you truck not come with one? Pretty easy to install. Or you mean you have no mean to get power to it? In my apartment complex I have no way to run a extension cord to it. It was nice at WyoTech that they had parking for diesels to plug in during the winter
6.4 Stroker
The truck didn't come with rapid heat. Like yourself I don't have a way to run power to it. Which sucks because last heat we hit -30 a few times.
