Air Gauge Locations
Duallytocamp
Wisconsin
I have a 2017 f350. I am in the process of installing my Viair tank and compressor. I have a round 2 needle gauge but cant find anywhere i can see it to locate it. Thought about wireless but do nest seem possible. What did everyone do? Thoughts?
PasoF450
I installed mine here:
Duallytocamp
Wisconsin
Interesting. I thought about it there but figured it wouldn’t fit. What did you have to cut? Being electronic does the airline s go into back still? How deep is gauge? Where did you put inflate delflate? I was going to use non electronic not wanting to spend money.
PasoF450
I used the uplitters switches to inflate and deflate the bags. The pressure sensors are at the air compressor and the 3 gallon tank. I drilled out a very small hole, maybe 1/4" to run the wires thru.
Duallytocamp
Wisconsin
How did you do that? Kinda confused? 1 switch to fill and 1 to lower? Did you use a gauge?
Duallytocamp
Wisconsin
ferris70
Nevada
I had mine installed in the center console
PasoF450
Thanks. What control makes the upfitter let air in or out?
You will need two 1/4 solenoids, tie them into your uplifter switches. You need and installer he will know how to do it. Its all really simple basic components and cost next to nothing.
