TBagAMouseTrap
Ive had my truck for about 10k miles so far. Before I ever drove it I installed arp studs with factory gaskets and machined heads, egr delete, new oem oil cooler, rr fuel with low pressure pump feeding stock. Since then I've installed a ported intake, 68mm pmax, 190/100 injectors and rebuilt the trans with suncoast kit. I've recently started to push coolant. Seen on here that the arp/stock gasket set up was good for 1000hp. I made 565hp on the dyno and ran a 13.2 at the track so I'm nowhere close to that. I read on another forum that the arps are only good to about 500hp and then they stretch, and that warren used brand new heads, oem gaskets, and new studs and after his first pull was pushing coolant. Do I need to move to the 625s, h11, or h13? I torqued the studs to the instructed 210ft/lbs. I remember the first set of studs I installed had a final torque of 245 as per arp. Should I just throw new gaskets in and torque to 245?
