Banks boost gauge
89 Stroker
Southern Cali
What is the wire on the back of a banks dynafact boost gauge for? Power or dimmer? Gauge came with the truck and was cleaning up the gauges and cut the back wire to remove the gauge, the gauge never turned on with the lights but it works
EPA
Should just be a ground... Should have 2 wires on the connector at the gauge red (power) and black (ground).
If they are both black just run 1 to keyed or light switch power (I think directions said center wire) and the other outer wire to a ground. All its for is the light bulb. If you only have 1 wire the other was probably cut or pulled out of the bulb connector at some point... So you would need to fix that first. Here is a picture of an old dynafact boost is on left...2 wires.
