Borg Warner S366 PSA Special - $600
SmedingDiesel
Brand new Borg Warner S366 Turbocharger Special!
$600 including shipping and handling
S300SX3-66 .91 A/R (Straight Compressor Outlet)
BorgWarner Airwerks S300SX3-66, S366, S300 91/79 with .91 A/R Twin Scroll Turbine Housing.
Rated at 500 to 830 HP
Compressor flow is rated at over 82lb/min
This is the largest of the S300SX3 midframe turbochargers from BorgWarner Airwerks line.
Wheel Dimensions:
Compressor: 66 mm inducer / 91.4mm exducer, with exclusive Extended Tip Technology.
Turbine: 80 mm inducer / 73 mm exducer. Cast in Inconel 713 for high-temperature operation.
Housings:
Compressor: Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
Turbine: .91 A/R Twin Scroll, with 'T4-style', divided entry, and 4.21" v-band discharge
Only 2 at this price. Call to order! 210-446-0888
fordfreak4life
I wish I had the money to pick on of these up my 190s need more air
Sent from my Milestone X2 using Tapatalk 2
windrunner408
Out of curiosity, can you guys get a S366 with either a 68mm or 71mm turbine wheel as opposed to the 73mm wheel??
