Brake Booster/Master Cylinder
rsieck
Midway, IA
I got a leak in between my master cylinder and booster. Is there just a o-ring or gasket between the 2 that I can replace? Don't really want to spend $140 on a new booster, if all I need is a gasket.
Arisley
Arlington, Texas
On a superduty, that's not a booster. Well I guess it is, our brakes are hydro boost. It has powersteering fluid in it. If you are leking brake fluid, it is probably a bad seal on your master cylinder.
rsieck
Midway, IA
It's not brake fluid for sure. Definately power steering fluid... And I meant hydro boost... LOL
Arisley
Arlington, Texas
I figured you know, My guess would be a new hydroboost. Might tear into it. It might be a simple to replace seal.
It would probably take hours to find the replacement seal, and you end up having to buy 40 of them and takes 40 seconds to replace.
