Hey guys, so I have a weird scrubbing/scraping noise coming from, it sounds like anyways, the right front end on the passenger side. It sounds like metal is scrubbing or scraping against something. I thought it may have been something stuck in the rotor, dust protecter rubbing, etc. so I pressure washed it and the brake pad/rim was steaming hot from the water. Also, I looked where some said it could be a hub so I played with popping it in 4WD when I heard the noise, and it seemed to have little, if any effect, on the noise.
So I took it to the Ford dealership, they found a rock had lodge in the brake, removed it, and I thought problem was solved. They also said wheel did not have any play in it, brake pads, rotors were recently replaced new on all fours, etc. I was WRONG. It still makes that horrible sound and I have no idea what it could be? Any suggestions or things to look for?
