blk350on20s
- Joined
- Jul 5, 2011
- Messages
- 2,720
- Reaction score
- 0
OK guys. Some of you know from my thread I'm having a braking issue. The truck feels like it has an extremely warped rotor. The worst rotor my buddy has ever felt and he worked at a pep boys in Detroit for over 6 years. Just idling the truck in drive going down the road and have slight pressure on the brake the pedal will pulsate back at you. It basically slowly pushes your foot towards you then back. It seems to be every revolution. Now go 5-10 mph and apply the brake like you normally would to stop and the pedal literally kicks back at you with every revolution and you can feel it grabbing the brakes hard for a split second as it kicks. It also jerks the wheel to the right and the right front makes noise. Almost like a clicking noise. Some have suggested backwards hydro boost lines but I found a pic from 2 days ago that shows they are not. One with blue tape goes to the one with blue tape which is always the inside one. I'm lost. I pulled the front apart and all pads, rotors and calipers look good and move freely. What you guys think? How can I bleed air out of the hydro boost? I have a guy going to systematically bleed the abs module today. Really hope that's it but none of the braking system as far as brake fluid goes has been separated.
