Build Thread
6.4f350
Since everyone likes seeing these....
Bent #1 rod back in January. I had the plow on the truck and had symptoms of a bad EPB sensor, gave it the beans a couple times in hopes of clearing out the EBP tube if it was clogged. Accidentally left the HD300 tune in the truck too. Turns out a wire was broken so all I managed to do was pour in the fuel at low RPM and skyrocket cylinder pressures. Truck started ticking once I got to where I was going, I first assumed it was a lifter. After tear down I found the #1 rod was bent just enough to let the bottom of the piston hit the counterweight on the crank. My wife and I had our son on 12/30, between him and work time has been in seriously short supply so I've only recently started making decent progress on this.
Parts list:
8 new pistons, shaved down 60 thou, delipped, and coated
8 new rods
Stage 1 cam from Dynamic Diesel
All new bearings, seals, gaskets from bottom to top
All new lifters
Already had ARP studs
All 8 injectors checked by MPD, one failed had to get a reman
BD manifolds/up pipes
H&S single kit
The piston that was hitting the crank:
Build pics:
Got a little carried away with my 0's on the markings, my rings are not set that tight lol
Yes that's a 2x4 under the crank snout. I don't trust all that weight on this dinky stand. Lol. Last thing on it was a fully dressed GT500 longblock so it's fine but they always make me nervous when they're loaded up heavy.
WILD_PHIL
East TX
Well glad you are finally able to get started on it. Good luck with the build.
E99 F350/zf6/guages/arp/comp/stellite/ billet wheel/ bellowed... Need more fuel and more air.
bigrpowr
<How I Fly
Administrator
Dare I ask why it's back in the frame rails with no heads on it ?
6.4f350
I don't have my uppipes yet and didn't want to fool with getting them on after the heads were already on. I could R&R heads in one of these things cab-on blindfolded at this point, no big deal.
