97 f250 won't stop squeaking & has only gotten worse. All the pulleys seem ok. The vacuum pump feels really seized up but still spins(with a lot of force). Whenever I spray water on to the belt between the fan hub & power steering pulley on the splined side, the squeak will go away. Is it possible the seized vacuum pump is causing extra stress somewhere else around the pulleys? The crankshaft pulley/harmonic balancer does look like it has a slight wobble to it as well... Any info is appreciated so money & time aren't wasted on new parts that aren't needed. Truck has 200,000 on it. Thanks. Also, just replaced tensioner pulley to no avail.
