Constant regen
DEEZUZ
NO PUKESTERS
NWI
Tossed a new depeeeff on a truck along with a new diff psi sensor. I can't get the truck to leave for more than a week. It's almost always regenning. All the pressures look great but for some reason I can never get the pid to read clean, it's always loaded or part loaded...
DEEZUZ
NO PUKESTERS
NWI
Entire ride home, 15 miles truck was in regen. First 2 blocks blue/white smoke. After that, nothing. Regen read active and egts confirmed it was indeed regenning. Depeef psi reading 0.17 to 1.7 psi
Stupid question but there wasnt oil in the downpipe was there?
DEEZUZ
NO PUKESTERS
NWI
All dry. Maybe something new popped up but, crankcase level has been fine
79jasper
skiatook, Oklahoma
I've seen something about resetting the adaptive tables with ids. Could possibly need a reflash.
Sent from my SM-N960U using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
Everything wiped clean and reset when I put filter on and last week I reset it again.
Mesa, AZ
Did you put a cat on it too? Seen a lot where it wont light off and get the deepeef hot enough to actually burn off
DEEZUZ
NO PUKESTERS
NWI
Regen the entire way into work. Face pressure was 0.19 to 3.5 cruising to wot. Regen started as soon as engine got to temp, status read loaded.
Egt temps coordinated with typical regen, 750-1100-800.
Slight blue smoke only after resting at stop lights upon take off.
Got to work, tossed it in park, regen went inactive. Pushed a manual regen, it's doing it now, no smoke.
Will report back but I bet it'll read loaded when done and I'll bet the counter doesn't reset.
DEEZUZ
NO PUKESTERS
NWI
Manual completed. Timer did not reset. Manually reset deeppff, now at 0.0 miles. Will let it idle awhile and drive again.
DEEZUZ
NO PUKESTERS
NWI
Removed dp at turbo and let run, all dry no haze, no smoke. Notta
Mesa, AZ
Try a cat maybe? I know your temps are good, but maybe its not burning the fuel right or something?
DEEZUZ
NO PUKESTERS
NWI
My only hold up is my depeef psi is well within spec, so why is it commanding a regen 24/7
dsberman94
Pennsylvania
Does it have more engine hours than mileage? I’ve seen guys with company trucks leave them idling 12 hours a day and they regen the entire time after idling for so much every day. Ive seen/smelt them 13+ hours straight on a regen. Kinda curious as to what you find. Cat is probably ***ed from the constant regen.
co04cobra
WV
Could try a complete pcm reflash to as built data or blank path it like a new pcm was installed. Might be worth a shot since everything else seems to be in spec.
