- Joined
- Dec 28, 2020
- Messages
- 277
- Reaction score
- 53
Had another new leak show up. this truck sits a lot now. Not sure if it is related to that or not.
Last leak was upper radiator hose, thermostat housing. Was all dry after that. Now I smell it, I see coolant in the valley.
Looking online, the two most common would be crossover pipe gaskets or turbo fitting. Both are completely dry with no staining.
Any Idea when they leak? Do I pressure test?
When the truck is hot and the system has pressure I don't see any leaks.
Or will it leak when it is running only?
Or is there someplace else it can be leaking?
