d.evil
Recently picked up a RCLB with 152k on it. Carfax was clean, overall truck is very nice for the mileage. Bone stock. It was sitting for a few months before I bought it. I've put about 50 miles on it, and its went into regen twice. I notice quite a bit of white smoke when the regen is on. Otherwise no smoke. No smoke on start-up. Fires right up, runs great, but am a little worried about the smoke. No codes or CEL. I pulled the oil filter cap and there is a little blowby, but nothing I would consider excessive (doesn't push my hand off when covering the hole).
We are doing a coolant flush, oil change and fuel filter change today, along with *** ******, H&S Mini, S&B intake, Coolant filter kit, no limit cold side pipe and Alradco intercooler as the stocker is pretty rough. We will do the ****** and see if it still smokes, and go from there. I am hoping its just from sitting for months and needing everything to be cleaned out.
I'm assuming if it still has white smoke with the *** ******d it has a cracked piston or bad turbo...?
