I was thinking flux capacitor.
^^^That's my vote. Of course, you gotta make sure your alternator is still putting out 1.21 Jigawatts.
Bubble gum? It smells better than JB weld!
what ever came of this? any update
Still waiting on ford to bring in a "part" IDK what "part" they are speaking of though they never told me what this "part" is when I talked to them last week.
Where's the spaceship?
Never seen the fuel cooler pumps go bad. When I head the head gaskets done on my 08, the fuel cooler pump came on and wouldn't stop running, couldn't figure out why. Had an air pocket at the lowest point of circulation. I'd check that first. You can always test the pump with a 12v source if you have any concerns.
When I had my cab up I was driving mine home from the shop with the coolant pump screaming as well. I just kept adding fluid and the eventually it stopped and then the coolant level maxed out maybe one fill up later
Did you try to put power to the pump? The pump is accessible by removing the inner fender, it's towards the front of the truck. If you have trouble seeing it just follow the coolant line down. Follow the wires and make sure the connection is good. I believe you said you have AE, I never used it before but can you command the pump to turn on with it?
Try to put power to it with a power probe. If it doesn't come alive then I would replace it
