willholl79
Will an unplugged or bad crankshaft position sensor cause a slow crank?
I put my truck back together after studs, injectors, etc and it cranks VERY slow. The batts are good, the starter is 1 month old.
The only thing I know that's not right is the clip is broken on the crankshaft sensor and the plug will not stay on. I am wondering if this is causing a slow crank.
