Dealer hassle
Bryce_fow
So I was sold a lifetime warranty with my truck but want to ****** it how many of y’all have been hassled ps I am leaving the egr and only doing a ****** pipe so if something goes wrong I can just slap it back stock and ride to the dealer
It's pretty simple. If the part that fails is compromised by the added power, pay for it out of pocket. If it is unrelated, it should be covered under warranty. Google Magnum Moss Act
Bryce_fow
Yea I was going to put it back stock if anything goes south
79jasper
skiatook, Oklahoma
All they have to do is hook up their fancy computer and it will tell them it has been tuned, regardless if you have set it back to stock.
Sent from my SM-G892A using Tapatalk
tbh, most techs dont even know how to check that...It isnt like a pop up appears on the screen and says "tuner alert!!"
I bet they would learn quick if it came in with a blown turbo or transmission though.
GloverPlatinum
Is there a good kit out there for the ****** pipe? Leaving the egr?
8WR_ZJ
I have the flo pro ****** pipe. Easy to put in. I assume it would be easy to swap back in if needed.
Sent from my SM-G965U using Tapatalk
qzillanut
I would say it’s best to talk to your dealer about it. Some are more willing than others to work around mods.
dmd
Denton, TX
Who supports that lifetime warranty? The company? Many of them will void any claim for the slightest thing. If they even suspect a ****** it will be voided I am sure.
ChattyCathy
I don't understand this logic.
Bryce_fow
60,000 dollars in you can call me whatever you want going from a 6.4 to this the warranty sounds nice to me so if I have to lie and cheat the system then so be it
Zeb
Downtown Marrowbone Ky
The fact that you openly admit to wanting to “lie and cheat the system” is brazenly low down.
If you can’t afford to fix it when you modify it and it breaks, LEAVE IT STOCK AND LET THE WARRANTY COVER IT.
Bryce_fow
Ok first off money isn’t the issue hints owning a 6.4 before this and I am not trying to cheat or lie I was just asking if someone had found away to get around the warranty y’all need to take a chill pill the only reason I care about the warranty is for the stuff internal not the turbo or injection pump because I would rather do that myself then take it to the ford dealer here so with that being said I drive all over the place so I was wanting to keep it close to stock Incase something happeneds when I am away from the house how much of a hassle it would be but I thank you for understanding every situation
