Deaver vs Atlas Springs???
Twinturbostroker
El Paso, Tx
So I was about to pull the trigger on a set of Deaver springs for the rear of my truck, to try to bring it up to par with the 4.0 coilovers and bump stops I'm running on the front.........well that was till I got the latest issue of Diesel Power and it has me wondering about Atlas Springs, as that seems to be the spring of choice of all these Dodge boys....... anyone know anything about Atlas springs vs Deavers???
http://www.youtube.com/watch?v=t90w2BMKl1I
ncollins64
winchester springs, tn
I can't say much about Deaver but I just bought atlas springs for mine. my front is lifted 5 inches. I took my 7 inch block off the rear and put equal height atlas springs in there place. They ride awesome. Mine is like a stage 2 system made for towing because I do load it quite often. These springs ride smooth and do not squat under load.
Twinturbostroker
El Paso, Tx
Stage 2 system??? I've gone their website, which is under construction, and Googled them, with very lil info on them......where did you get yours?
Zmann
My dealings with Deaver have been great
they taper the end and use more leafs that are thinner for a better ride
the Atlas I found has a chitty website with no info so no comment on their construction
powerstrokedkid87
New Jersey
I have deavers currently in the rear of the red truck.....ride is awesome.....on the same note, i had ridden many miles in a truck with Atlas springs....i think they are equally as good. Im sure the suspension gurus will pipe in more, but i would say you would be happy either way.
Rodslinger
Lake Havasu City, Airidzona
I have Deavers in my Ex. They work bad azz. I think that if you tell either company what you are doing, weight of the vehicle and lift height your looking for, they will set you up with a good ride.
Twinturbostroker
El Paso, Tx
I've heard nothing but great things about Deaver and ridden in many many trucks that have them.....hence why I wanted to get a set, but after that DP article and not finding much info, it has me wondering.....not to mention there is considerable price difference
Is it the same concept as Deaver, multiple thinner leafs??? Or same thick leafs? Thanks for the info
TripleE44
Keller, TX
Not to throw another company at you, but I checked on national too when I was trying to make my 08 ride a little smoother in the rear. I emailed them and they said they'd change them to make the truck ride however I wanted/needed it to ride.
I really think either company will get you what you want if you explain what you want to get out of the springs.
ncollins64
I asked for a guy named Fernando. He told me theres 3 stages. Stage 1 being just for comfort and smooth riding. Stage 2 is smoother than factory but is for towing also. Ive got stage 2 And mine does not squat even with a loaded gooseneck. Stage 3 is just for towing HEAVY and is a harsh ride. I think mine are 11 or 12 leaf packs with military wraps and so far iI love them.
Zmann
I would run stage 1 and have airbags for towing if it were mine
smokinstroker
Texas
well after talking to a VERY reputable shop today, they told me that no aftermarket spring is going to ride better than the factory spring.
I was told that the aftermarket spring companies adding extra leafs to the pack are only doing that to try and control the axel and that I will not help my ride.
im stuck, as im not very happy with the rear end of my 08 unless I leave 500lbs in the back of it.
SSpeeDEMONSS
6mi from the beach, SoCal
Have a custom set made then. Have you tried calling the spring manufacturers themselves and seeing what they have to say?
Garrett
probably getting paid at work to post this from my bionic
TrueBlissCustoms
SoCal
I have the atlas springs on my 450. Not happy with them at all. They were supposed to send me + 7" springs for the rear so I dont have to us any blocks at all. They sent me springs that were A) 2" taller than stock B) dont have a load carrying capacity more than a ford ranger AND C) they started rusting after a few trips to mammoth and big bear.
When I called fernando back he said that we should have calculated that there will be sag in the rear leafs. Now to make the back end of my truck about 1" lower than the front I had to run a 5" spacer.
Didnt like them at all. Wont recommend it.
Rodslinger
Bullchit. If you have a company that builds the spring RIGHT, it's night and day better.
Zmann
that is Bullchit
and Truebliss you got hosed as you know
good enough endorsement for Me never to run Atlas FU Fernando
talk to Scott at Deaver
