So the truck has a bigger oil to coolant temp gap than it should, highway at 70 coolant is 178-182 and oil is 190-198 they both fluctuate a bit. Question is on a deleted truck whats the big deal if your running a 17-20* delta? Provided the temps are low enough on both sides to not boil over or start melting chit.
The over 15* gap isnt throwing and codes.
Also to go along with that, i know my coolant temp is a bit low seeing as it doesnt hit 190 ever. Should a deleted truck run a higher range thermostat? Makes sense to me due to the coolant not cooling the egr thus not reaching the temps it would with egr.
But with the coolant temp hotter obviously the oil temp would rise accordingly and then oil will be over 200 i dont think it would reach dangerous levels though.
Am i over thinking this or could i be in for another oil cooler sooner or later?
