bryan.d
I have an E99 that is giving me trouble. It starts and idles fine until it get warm then it starts to miss like it running on 4 cyl. Appears to start missing on one cyl. at first then gradually gets worse. I pull over and let it idle with a little revving it up there is some greyish/white smoke from the tailpipe and knocking and it clears up and idles fine. No codes with OBD2 reader. Then I proceed to drive on and the same missing starts again. The symptoms started all of a sudden while driving felt a stumble then the problems started. I have been searching this site and others with little luck. The truck has 248k and i purchased it with 170k. Mostly stock with the exception of exhaust, 6637 air filter, and SCT canned tunes. I have replaced both UVH (motorcraft)and one VC gasket (felpro. waiting for the other to come in). One of the UVH and VC gasket had a burnt terminal(drivers side). Oil level is good. Fuel is good and clear. Hopefully someone with more knowledge than me has a little insight on the problem. Thanks for reading and I apologize for the the long read.
