A while back I had posted about my truck randomly shutting off and not running again. It fires up for a second and then shuts off. I've checked out all of the basic stuff while cranking icp, ficm, ipr, battery voltage, sync, fuses, grounds appeared to be alright, fuel pressure and tried a different injector harness. Everything checked out ok but it still doesn't run. The closest plug in to the cab on the ecm does smell pretty burnt. Is there any way I could test it? Or anything else I should look for because I'm running out of ideas.
Thanks.
Thanks.
