Electric fans
ingrahams
New Hampshire/Africa
Well I finally took my truck to the track only to have it puke all the coolant out of the reservoir. Found that the electric fan controller had fried and the coolant cap wasn't tightening down far enough. Do I need to run a controller or can I run a relay off the wiring that went to the clutch fan? Looking at runnin 2 spal 12" fans just trying to figure out the best way to control them. Thanks
-Stew
devdiesel
Barrie, Ontario
Flex-a -lite has some bigger E fan options. I'm running 2 16" fans I believe, just off of a switch in cab running through a relay. Might not be automatic but it works perfect
gman1
Michigan
I had to make some of my own parts but for the most part its a good fit. You can set the temp for when the fans come on or use an up fitter switch for manually turn on.
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
The last pic is how I mounted the lower part to the rad.
