Engine fan stuck in low speed
jcain
No rhyme or reason or mods done at the time. Engine cooling fan seems to be stuck on low speed non stop.
Trucks Temps are 190s
Outside Temps are 70s
A/c is not on
Coolant level is good
Radiator is not obstructed
Fan is on on cold start and warm start
No dtc (codes)
Any tests I can do relatively easily ? I'm a long ways from home and have minimal tools and no IDS
Someone else posted their fan doing something wacky when they tuned with ez lynk....
May not be related tho
Mesa, AZ
Try turning it by hand with the engine off. I have seen one fan that was seized, it was on high, but yours may have some slippage still.
powerstroked08
Pennsylvania
It should have some resistance. It's a visoelectric fan. Should feel like your turning it under water if that makes sense.
jcain
Was the fan clutch
Guess they still have problems with them seizing up
