mikeeg02
If your empty, drop the rears to 40 . That's where I run my 16" dually rears empty ~55 in the front
I agree. I was surprised the other day when I put a pallet of sakrete in the the bed. Even with that at 40 psi the tires had plenty of room. Though I have the stock 235/85 size. A pallet of sakrete is ~3,300 and it ended up sitting rearward, because they couldnt push it in because of the tailgate.
Anyone ever change out the front springs on their F450? Was curious what I could change mine out to mailnly for smoothing up the ride some but also lowering it by just a hair (will take out the rear lift block also to level it back out if need be). I don't tow anything but a jet ski and a small single axle trailer now days so I'm not concerned about reducing the weight capacity.
The problem comes from the sidewalls getting hot from being under inflated for the weight.
Have you figured out how much weight the tires can hold at 40psi?
the anemic 450 d80 years SMH
OP has is a real 450 with a D110
I may be mistaken but I believe the pickup 450s come with 350 running gear, and the c&c 450s came like a real 450. Not sure if that's changed. I'm still pissed they bought that truck, paid 10k too much for a lighter version of what they wanted I told them not too, but they had to learn the hard way.....
I have personally never seen a tire data sheet that gives tire ratings at anything other then a max rating (not to say there arent tires rated that way, I just havent seen it myself) at 40 psi in a DRW configuration, even with that pallet of sakrete on the bed (though only a 25 mile trip home from lowes) the sidewalls were not any warmer then usual. Towing regularly heavy, or when I get loaded for coal which puts ~1.5-2 ton in the bed, plus another ~4.5-5 ton in the trailer I will air up my rear tires. I wouldnt advise to tow heavy at 40 psi but.............
Like I have quoted above, he typically drives it empty and even when he tows he is towing a jetski or a small single axle trailer. If he gets 2k on the tongue of that truck, I would be surprised. I keep my rear tires low to help with tire wear, because anyone running 235/85-16's knows they always wear out the center before the outer lugs, its just the dually way.
In a SRW configuration, I have never had any trouble running 65psi flat. Though in a short bed configuration, so less can be put on the rear axle, and the trailer tongue weight properly setup. Just my experience, your mileage may vary.
https://static1.1.sqspcdn.com/static/f/589830/23447320/1378330097907/Discount+Tire+inflation.pdf
