Feedback on 62mm SPE
Jada816
Georgia
Im thinking about doing the Spe 62mm upgrade to my charger is it worth it? new wheel machine compressor housing and remove silencer ring. I have a 2012 that i put a 17 charger on full upgrades with 15+ hpfp...
Swaan
Mmmmmmm now this sounds interesting. I got nothing for ya but you've sparked my interest in the mod.
Jetskimadness
Also looking into this modification. Is there anyone running around with this setup? I have a 2015.
Swaan
Looks like you have to send your charger in to these guys to get the mods done. So your looking at down time plus the actual re@re of stock charger..
It's not just a simple do it yourself mod.
But still a lot cheaper then a whole new turbo
Powerstroke214
Baton Rouge, LA
I don't see a real benefit unless it DEFINITELY spools better. I don't think the actual bump in power over the stock charger is worth it. Just my uneducated opinion.
alewis
I’ve never heard any feedback on that charger... would love to hear some.
harrelljr99
They claim the same hp gains as a 63 fleece. They say their reason for 62mm was that 62mm turbine according to their research was most efficient.
650 hp capabilities WITH a stroker
I don’t think you’ll be satisfied with the gains of just the turbo you’ll have in the back of your mind.....if I had a stroker.....
15pearl6.7
Not worth the money IMO.. If the turbine is going to be untouched there is no point in getting a modded compressor side on this particular application.. I’ve ran 3 different company chargers “per customer request”.. Couldn’t tell any change afterwards other than lighter pockets and the same hp truck.. 😂😂 You’d enjoy a nonvgt a lot more
That's a crock of chit
Wicked
Fairhope, AL
On Powerstroke.org I remember reading someone testing different compressor sizes and blades. They did make a little more power, shifted the hp and tq to the right, and maintained higher hp/tq in the upper rpms. I’m trying to see if someone will do a 10 blade turbine with the stock compressor wheel. I’d rather have low rpm tq and hp instead of shifting that to a higher rpm for better everyday drivability but with some more whistle.
HeavyAssault
Middle, VA
I recall KC turbos did some dyno runs showing the differences in stock, drop in billet, and their design compressor wheels. Biggest thing I saw was the values moving to the right. Drop in was better than stock but not what they wanted.
Black AOD
Ohio
VGT's on these truck are massively restricted on both sides as far as the turbo wheels but the turbines are where the big gains are to be made.
That's why the fleece and KC units are so popular with the bigger turbine wheels that come in them.
