1FTXW42R98EA16695
AWS Claim Key Repair Date -
Detailed Vehicle Specification
VIN1FTXW42R98EA16695Vehicle LineT/F7Market Derived CodeFBody CabT/BCVer. SeriesT/DBDrive TypeT/BPLT CDA1TRS CDT/BEENG CDT/QLProduction Date16-JAN-07Warranty Start Date03-MAY-08Selling Dealer152168Selling CountryUSA
AWS Claim KeyTrx CodeTime In ServiceLabor HoursDealershipDIST (Miles)Repair DatePrefixBaseSuffixDoc
Details1097107S490.5LAWRENCE MARSHALL FORD-MERCURY626-MAR-07***12176601Customer CommentsRECALL 07S49 REPROGRAM PCMTech Comments1 RECAL PCM
Details185137308B076.5PLANET FORD LINCOLN899321-OCT-08***46444103Customer Comments6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE ( PCM) AND INSTRUMENT CLUSTER (IC) 08B07Tech Comments1 REPRGRAMMED MODULES PER RECALL
Details185137208B066.3PLANET FORD LINCOLN899321-OCT-08***46444104Customer Comments6.4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION 08B06Tech Comments1 INSTALLED VENTURI TEE
Details1851374268PLANET FORD LINCOLN899321-OCT-088C3Z9A332A46444102Customer CommentsE68 CUSTOMER STATES VEHICLE IS LEAKING DIESELTech CommentsVERIFIED CONCERN, FOUND LEAK COMING FROM PASSENGER SIDE FUEL SUPPLY TUBE, R AND R CAB ASSEMBLY, REMOVED U PIPES AND HEAT SHIELDS, REPLACED FUEL SUPPLY TUBE, RESTORED REST OF VEHICLE PURGED AIR FROM HP FUEL SYSTEM, ROADTEST, NO CONCERNS, M TIME TO REPLACE FUEL TUBE, NO OPS
Details280719808B06102.7PLANET FORD LINCOLN1679113-FEB-09***47543502Customer CommentsL87 CUSTOMER STATES TEMP GAUGE WILL NOT MOVE AND IS LEAKING COOLANTTech CommentsVERIFEID CONCERN, PRESSURE TEST, FOUND RADIATOR LEAKING, REMOVED AND REPLACED RADIATOR, RETEST OK NO LEAKS
Details2807197S07101.3PLANET FORD LINCOLN1679113-FEB-09*7000*47543503Customer CommentsP69 CUSTOMER STATES FEELS LIKE TRANS IS SLIPING ON ACCELERATIONTech CommentsPERFORMED TRANS ELECTRONIC DIAG (SYSTEM PASSED NO CODES) TEST DROVE AND FOUND AUTO TRANS OPERATING AS DESIGNED
Details422894508B0616.9LONE STAR FORD2967525-AUG-09***658330ACustomer CommentsCHECK COOLANT LEAKTech Comments29685 CC D8 FAILED ORING SEAL INSIDE UPPER RAD HOSE AT TSTAT LOCATION VERIFIED CUST CONCERN OF COOLING SYSTEM LEAK. PRESSURE TESTED COOLING SYSTEM AND ISOLATED LEAK TO UPPER RAD HOSE SEAL AT TSTAT HOUSING. DRAINED COOLING SYSTEM REMOVED AND REPLACED UPPER RADIATOR HOSE ASSY . REFILED COOLING YSYSTEM WITH PROPER MIXTURE . RETESTED TO VERIFY REPAIR OF LEAK. RELEASED VEHICLE.
Details4657617E8318.6LONE STAR FORD3345019-OCT-09BXT65750662375ACustomer CommentsWILL NOT CRANKTech Comments33451 CC 42 BXT 750 BOTH RIGHT AND LEFT BATTS FAILED TEST VERIFIED CUST CONCERN OF NO CRANK. PERFORMED BATTERY TEST WITH MIDTRONICS TESTER. RIGHT SIDE BATT ONLY 554CCA AND BAD CELL(DTC 16QJS CDDS0 01K ACES XEA8H)LEFT SIDE BATT ONLY 54CCA (DTC 10LJS VJBS0 80W ACES XE18H). REMOVED AND REPLACED BOTH RIGHT AND LEFT BATTS, PERFORMED CHARGING SYSTEM TEST OK AT 14.1 VOLTS AND 45
Details4600569S07183.2LONE STAR FORD3345019-OCT-098C3Z8575C662375BCustomer CommentsTEMP GAUGE STAYS ON COLDTech Comments33461 CC 42 (8575) TSATS STAYING OPEN ENGINE TEMP TO COLD. VERFIED CUST CONCERN OF TEMP GUAGE STAYING ON COLD.PEFORMED TSAT DIAG, RETRIEVED DTC OF P0128 WHICH INDICATED TSTATS STUCK OPEN. DRAINED ENGINE COOLANT, REMOVED COOLANT DEGAS BOTTLE, UPPER FAN SHROUD EGR VERTICAL COOLER LOWER BRACKET AND HEATER HOSE TO GAIN ACCESS TO REMOVE BOTH PRIMARY AND SECONDARY TSTATS.
Details4961173E84204LONE STAR FORD3498507-DEC-093C3Z6701B665744BCustomer CommentsCHECK OIL LEAKTech Comments35005 CC D8 (6701) REAR MAIN SEAL FAILURE CAUSING OIL LEAK VERIFIED CUST CONCERN OF ENGINE OIL LEAK. PERFORMED ENGINE OIL LEAK DIAG WITH BLACK LIGHT, ISOLATED OILLEAK TO REAR SEAL AREA. REMOVED AUTO TEANS ASSY AND FLYWHEEL TO GAIN ACCESS TO VERIFY OIL LEAK FROM REAR SEAL. REMOVED AND REPLACED REAR MAIN SEAL. REINSTALLED FLYWHEEL AND AUTO TRANS ASSY. ROAD TESTED AND RECHECKED
Details4961172S0720.7LONE STAR FORD3498507-DEC-097C3Z6K775B665744ACustomer CommentsCHECK ENGINE EXCESSIVE WHITE SMOKE THRU EXHAUSTTech Comments34995 CC 42 (6K775) CHARGE AIR COOLER ASSY CAUSING CONDENSATION SEE TSB08 25 1 VERIFIED CUST CONCERN OF WHITE SMOPKE IN DAMP WEATHER UNDER CONDITIONS OF TSB. QUALIFIED FOR TSB 08 25 1. REMOVED AND REPLACED CAC PER TSB, ROAD TESTED TO VERIFY REPAIRS. LABOR OPS 082501A (0.7)
Claim Details
close
PrintClose
