Front main seal replacement
Chris2590
Bristol Indiana
I’ve done some searching online and can’t find much info on replacing the front main seal. Any special tools or parts needed? How much of a pita is the job? Any help would be great
Magnum PD
VA
Some have a wear sleave or you can put a wear sheave on the front balancer
DEEZUZ
NO PUKESTERS
NWI
Man it's been so long that the only thing I recall about the job is to put a dab of rtv on the keyway when assembling
Chris2590
Bristol Indiana
Lol well that helps a little. I found the riffraff instructions online. It just seems like a lot of specialty tools to rent
Magnum PD
VA
You need a harmonic balancer puller to get access to the pump.
rusty1161
Whittier, CA
All you should need is the balancer puller/installer. You can borrow/rent it from a local auto parts chain store for free most of the time. The rest is common tools unless your balancer is grooved.
Rusty
