Taylor D
This kit is new and is made to be attached to the catalyst pipe where the horizontal egr cooler use to connect and then dump to atmosphere.
This is going for $899 online I will sell for $775 Shipped
The H&S Motorsports 342001 Wastegate Kit addresses the common problem of excessive drive pressure in your 08-10 Ford 6.4L Powerstroke. While elevated pressures are a known issue on a stock truck, performance upgrades such as aftermarket tuning and nitrous are known to amplify drive pressure levels, this can harm engine components such as turbochargers and head gaskets.
Designed as a bolt-on, this Wastegate Kit attaches to the factory driver side up-pipe and vents excess drive pressure to the atmosphere. On test vehicles, H&S has seen drive pressures virtually cut in half along with gains of 10-30 HP. Since each application will differ, wastegate regulator adjustments may be needed to find what settings are optimal for your truck.
Features:
Bolt-On Design
Reduces Drive Pressure
Requires H&S High Sulfur Tuning
Note: This product requires the use of H&S Off-Road High Sulfur Tuning. It is not street legal and is only designed for off-road race use only.
Features:
Bolt-On Design
