H&S MCC coast clutch
TD-5
British Columbia Canada
In the transmission file you are using, go to engine braking and change "Gear in which engine braking can occur normal mode" from 6 to 1. this will disable the coast clutch in all gears. If you want the coast clutch to function say in 1st and 2nd, then change the number to 3.
Black Hawk
Pittsburgh PA
Thanks TD-5! My Parameter Tree doesn't have Engine Braking listed. I think i have old definition files. Would you send a copy of your definition files?
TD-5
What Tuning Version # (TV) is your program. Your H&S may be a knock off version with a hybrid tuning version installed. send me a PM with your e-mail and I will send you what I have.
Black Hawk
Pittsburgh PA
When I load the canned tunes the Verison # is, TV-6.4.52. When I load my custom tune the Version # is, TV-C.U.S.T.
TD-5
That looks basically the same as mine. I thought 6.4.51 was the last update they made in August 2013. Maybe there was one more.
