H&S Mini Maxx / TPMS Question
mattmal9
Severn, Maryland
I have a 2011 350, running the Mini Maxx, Im about to order wheels and tires for it. My question is, does the mini maxx have the capability to turn the TPMS system off ? Id rather turn it off then buy new sensor for the new wheels.
Thanks for the help.
donniesd
Yes.
http://www.hsperformance.com/mini-maxx/2011-2012-6-7l-ford-powerstroke-mini-maxx-street/
TPMS Adjustability / Disable
Many 2011 – 2014 6.7L Powerstrokes are equipped with a TPMS or Tire Pressure Monitoring System from the factory. This system is designed to alert the driver of a problem with the vehicles tire pressures but is often a nagging inconvenience for those individuals wanting to run lower pressures or get rid of the TPMS sensors altogether.
With your H&S tuning device, you have full control of the TPMS. Front and rear tire pressures are independently adjustable from 0-120 PSI as well as the option to disable the TPMS completely if removing the TPMS sensors from the vehicle. This option only takes a few seconds to change and can be adjusted at any time from the Tire Pressure Calibration menu.
Note: TPMS adjustments will not take full effect on a stationary vehicle. Once adjustments have been made, it can take up to 5 miles of driving before changes take effect.
