HELP!! Ahhhhhhhhh 6.0
lowKuntryMilitia
Ok 05 6.0 has head studs and egr cooler delete so im driving home get dead pedal very little boost black smoke rough idle, get home tube going to map sensor busted, replace tube and truck runs perfect! Drive 2 miles and truck does same thing, dead pedal very little boost takes forever to get to 10lbs, check hose its fine, check all other hoses there all good? Wtf, now truck idles rougher and gets white smoke out exhaust no check engine light....
Things checked and replaced so far:
Map sensor tube
Cac boot hot side nearest turbo
EGR cleaned
Took off fuel filter started with hot wire from starter no bubbles in bowl so no open injector? Im guessing
What yall think?
Gary
South Lyon Mi
To diagnose this you need to scan it and see what codes you have. With out the codes your only guessing, and guessing gets expensive.
lowKuntryMilitia
Thanks gary, will the generic scan tool from advance pull sufficient codes or do i need some real expensive one
